Hello Sun1234,
Maxwell is FEA tool and calculate machine performance based on input. When having same input, we should get the same results for each simulation.
However, in real situations, we may have some discrepancies for each test because of temperature, speed tolerance, voltage distortion, etc.
If you could change them, you may get different results. You could measure current and use them as input in Maxwell model. Thanks.
Howard
