May 17, 2023 at 11:49 am
My model implies that solid particles and gas come out of the nozzle with a solid cone spray torch at the same time. The gas is a continuous phase, the particles are discrete.
In DPM (as I understand it) I set the speed and shape of the solid cone only for particles (a photo of the DPM panel with the parameters I selected is attached).
But, as I understand it, from the inlet with the parameters that I set, the gas flow does not come out in the form of a solid cone, but simply perpendicular to the plane (this is confirmed by the shape of the flow after I started the solver and got the results)
