dbhands
Hello, thank you for your response. In this case, I am the network system admin. I know that I can specify to use IPOIB through name resolution, but to use RDMA I would assume I would need to actually specify the Infiniband HCA and not just IPOIB. Will RSM be able to auto detect if RDMA is available through each node by specifying the MPI NETMASK variable?
