Hello Daniel, To get to this Menu, choose: Simulation Tab, then Analysis Config:
You can also get there by: Tools->Options->HPC and Analysis Options Then Double-click on the Local Available Configuration That should get you to: Where you can change the number of CPUs and memory...
