Hreetabh Kishore
Sir,
The format i need is a column of time and a column of temperature for each node in an array. There is no specific format, i need. The matlab code will read text file of these collected data. I need not x,y,z data. Moreover, after decimal 3 digits are ok. Look on the below figure. Suppose I have selected 100 nodes. And I want time-temp data for each nodes of all time steps, 200 (provided during simulation). which means a total of 200 columns will be there. 100 for time and 100 for temperature. This is teh only requirement in the form of text file. But problem is I cannot select each node at a time to acquire the data. I want to get the data simultaneously for all at a time to get recorded.
Thanks!
