Hi Hilary, in SpaceClaim, look on the Assembly tab. If you put the object in a component, you can use the Tangent tool on the Assembly tab to align a surface or plane in the component with a plane on one of the global axes. You might need to use the Move tool to manually get the the planes roughly parallel, then the Tangent tool will make them exactly parallel.
