May 18, 2023 at 10:10 am
Hi Ashish,
I tried an inverse selection for multiple faces on solid geometry, and it works. However, it does not work for faceted geometry. The faceted geometry is a result of topology optimization.
I tried the inverse selection for multiple faces on another PC with different faceted geometry, but it either does not work. I'm using ANSYS 2023 R1.
I believe more people must have had this problem when validating the model after topology optimization.
Thank you.
Martin Štěpánek
