Dave Looman
Your commands still select the beam elements, 188.  Is that what you want.  Your *get command in solution is not going to work.  If you notice, my *get command was issued after creating an etable item in post1 and summing it with ssum.  That's not going to be possible from within the solution module.  Perhaps you didn't mean to issue /solu, but if your loop is to be executed from post1 then there should be a set command to store each result and etable/ssum commands like I did.
