Lora Fame
You can extract the values of the angle of curvature as a function of the distance x by using the displacement fields obtained from your FEM analysis. In particular, you need to calculate the derivative of the vertical displacement field with respect to the horizontal coordinate x. This will give you the angular rotation of the beam at each point along the length. To hire a dedicated development team, you will need to determine your development needs, research potential service providers, assess experience and capabilities, negotiate terms, and monitor progress https://mlsdev.com/blog/hire-a-development-team.
