I have set the surface tension equal to the 0.072N/m and the wall adhesion model is used as well. Also, both the bottom and side are modelled as walls in boundary conditions.
Also, the free level is at height of 0.008m from the bottom wall. I am very thankful for your suggestion about contours and would adopt your suggestion for this later on.
Best Regards
Zeeshan
