javat33489
Thank you very much for your analysis. I also set the damping factor to 0.
I had a mistake, I forgot to remove the initial acceleration, thanks. But it did not help.
I removed the initial acceleration, set the predict for impact, and set the damping factor to 0, this is what happened:
When I add time to the first step, the part stops moving at all:
It seems I've tried everything.
