May 18, 2023 at 6:51 pm
I solved it by myself. I leave the question and the answer for those who have the same doubt.
Just write a .txt file with the commands you usually enter in the Command Prompt and save. Remembering to insert the command /PREP for the preprocessing phase, /SOL to calculate the solver card and /POST1 for the Postprocessing.
To use it, just open a new project and then File > Read Input from… and select the .txt file.
I attach a photo
