NickFL
it is not supersonic at inlet.
If it is not supersonic at the inlet, then go back and review the boundary conditions. The outlet boundary is supersonic in your calculation. This means, if you were expecting subsonic flow, that there is a problem here. When the flow is supersonic it uses the upstream inlet conditions and the downstream is swept away (the characterstics of the equations do this).
