Look at the flow field around the engine, and post some contour plots. Post with node values off as that'll help explain if there's a problem.
If you left the PBCS Courant Number at 200, try about 50: the defaut can be a little optimistic. What other flow boundaries are set? Specifically the "outside" bound.
