35020306
Thank you for your answer Peter. I'm checking the status of my contact regions using Contact Tool and I found out that some regions are open when they are supposed to be closed.
Any idea what caused this? I used "Create Automatic Connections" to generate the contacts. Should I delete these problematic regions and manually make contacts between them?
