May 19, 2023 at 6:51 pm
Hello Federico, thank you so much for the help. I did not find any change in the deformation of the walls using the above mentioned advice. However I have a query regarding this. Is the condition that only "smoothing" with the above mentioned settings are turned on and "remeshing" and "layering" turned off. Or is that not necessary and all three can remaing " on" at the same time?
Secondly I cannot access the given link for some reason. Could you please provide me the screenshots of the relevant sections if it is possible for you in your busy time? I would be really grateful.Thank you so much again.
