Hello Peter,
After the element orientation is defined based on a local coordinate system, will it be possible for the local coordinate system to rotate with the model as the applied force increasing so that the element orientation change accordingly? I am asking about this since i want to define a model with orthotropic material, with the large deflection on the principal axes of the model will deviate from the original local coordinate system. Thank you in advance.
