Hemant Gurav
Hello ,
You can follow the methods mentioned here to display the Pressure contours distinctively.
  • From Contour window, hit compute and check for the pressure range, unselect the global range , auto range option and check clip to range option . Set the minimum and maximum pressure values as per your requirement .
  • Click on colormap option in contours panel and change the settings according to your requirement , also you can set coloring option to banded or smooth to check which looks better
    To know more about these options please check  Customizing the Graphics Display (ansys.com)
    If you are not able to access the link, refer to this forum discussion: How to access the ANSYS Online Help
