Carlos
Hello again,
I attach the field pattern for each port. Also, I include the configuration for the wave port configuration that I used. As you can see, every port has a different polarisation. How can I achieve to get the same on each of them as horizontal or vertical direction?
Thanks again.
Field pattern for port 1
Field pattern for port 2
Field pattern for port 3
Field pattern for port 4
Field pattern for port 5
Field pattern for port 6
Field pattern for port 7
Field pattern for port 8
Field pattern for port 9
Wave port configuration
