ricardo.pferreira
Hi Rob,
It seems that the mass flow rate at the outside bounds it is not the same. Does it can influence the results?
Moreover, since the sum of mass flow rates at the outlet is 1713.9 kg/s it was not supposed to have a similar value at the inlet of the engine? I'm having this:
Thanks!
