In Workbench, right click on the title bar of the first Modal analysis with all the layers and select Duplicate from the drop down menu. You can make as many duplicates as you want to separate out the layers. You can rename each Modal system to know what layers are active in each block. Then there is just one Workbench project file and folder.
