Jared McFadden
Hello Peter,
Thank you for the clarification. The only messages I am seeing that stand out say "Multiple constraints have been applied on degree of freedom 1 of contact node of 30539. The program will remove certain internal MPCs. Please check the model carefully." and "The contact staus has changed at 29 contact points."
Could either of these be the cause of the issue?
