Thandiwe Radebe
I applied the Full Bounancy effects under the K-e turbulence model. But it seems like the model still behaves the same.
The convergence is quick since I set it to 20 iterations, but within 10 iterations the solution converges.
I just want to know what are the implications of not including the Pure Solvent Melting Heat, because it seems to be the one that causes the model to become unstable. When it's set to '0' the model runs well.
is it impractical to leave out the Pure Solvent Melting Heat in this case, since i am freezing a liquid?
