Pranshu Kharbanda
Yes, I was expecting to see the block breaking free in transient however the solution is unable to converge. Even the block moves 0.6 mm only. I have applied force in steps from 0 to 0.5 N
I tried to reduce the minimum time step to 0.01 s, and the displacement increased to 5.774 . However the solution still couldn't converge.
I am not sure if I am missing something simulating this, as I thought block sliding on surface is relatively simple from physics perspective but the simulation is not converging here. The block is also not moving in a straight line it seems.
The error and warnings are as below,
