Hello Nanda
Thanks for your reply!
I will change the contact setting and run the solution again.
I want to ask a question.
Contact settings between displacement plate and model-->Interface treatment,if i set "adjust to touch" is ok? or "add offset,ramped effect" is better? or there are another suggestions?
thanks you very much
Liao.
