Hello Chaitanya,
thank you for your prompt reply! I can easely agree with any of your setup statements, I know that can be far from good or "correct".
The real fact is that I had a project in FluidFlow (CFX), with the same exact setup, which was solved withou errors and gave me results. My very first attempt was to change some setup input values. Then I found errors. My second attempt was then to simply re-run the same exact setup in that project, which eventually led to errors where previously where not!
My last attempt has been to reproduce from scratch in another project, with the same first solved setup, but still getting errors.
The fact which triggers me is that the initial, solved, project is not able to be solved anymore without changing anything, exept for the directory location on my workstation (the workstation and release of ANSYS is the same). This is why I also thought about some licensing or directory path problem.
I attach the initial project .outfile if can be usefull. I double-checked it and it's exaclty the same as the one atteched in the starting thread.
This run of the CFX 2021 R1 Solver started at 10:08:45 on 08 Feb 2022
by user Stefano.CHIETI on ------- (intel_xeon64.sse2_winnt) using the
command:
"C:\Program Files\ANSYS Inc\v211\CFX\bin\perllib\cfx5solve.pl" -batch
-ccl runInput.ccl -fullname CFX_003
2021 R1
Point Releases and Patches installed:
ANSYS, Inc. Products 2021 R1
SpaceClaim 2021 R1
Autodyn 2021 R1
CFD-Post only 2021 R1
CFX (includes CFD-Post) 2021 R1
FENSAP-ICE 2021 R1
Fluent (includes CFD-Post) 2021 R1
Forte (includes EnSight) 2021 R1
Polyflow (includes CFD-Post) 2021 R1
TurboGrid 2021 R1
Aqwa 2021 R1
Customization Files for User Programmable Features 2021 R1
Mechanical Products 2021 R1
Icepak (includes CFD-Post) 2021 R1
Remote Solve Manager Standalone Services 2021 R1
Viewer 2021 R1
ACIS Geometry Interface 2021 R1
AutoCAD Geometry Interface 2021 R1
Catia, Version 4 Geometry Interface 2021 R1
Catia, Version 5 Geometry Interface 2021 R1
Catia, Version 6 Geometry Interface 2021 R1
Creo Elements/Direct Modeling Geometry Interface 2021 R1
Creo Parametric Geometry Interface 2021 R1
Inventor Geometry Interface 2021 R1
JTOpen Geometry Interface 2021 R1
NX Geometry Interface 2021 R1
Parasolid Geometry Interface 2021 R1
Solid Edge Geometry Interface 2021 R1
SOLIDWORKS Geometry Interface 2021 R1
ANSYS, Inc. License Manager 2021 R1
Setting up CFX Solver run ...
| CFX Command Language for Run |
LIBRARY:
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Option = Pure Substance
Thermodynamic State = Liquid
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Reference Temperature = 25 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
ABSORPTION COEFFICIENT:
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
THERMAL EXPANSIVITY:
Option = Value
Thermal Expansivity = 2.57E-04 [K^-1]
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: CONVERGENT
Coord Frame = Coord 0
Domain Type = Fluid
Location = B2646
BOUNDARY: CONVERGENT Default
Boundary Type = WALL
Location = F2647.2646
BOUNDARY CONDITIONS:
MASS AND MOMENTUM:
Option = No Slip Wall
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
BOUNDARY: Interface Convergent Volute Side 1
Boundary Type = INTERFACE
Location = F1861.2646
MASS AND MOMENTUM:
Option = Conservative Interface Flux
END
TURBULENCE:
END
END
END
BOUNDARY: OUTLET
Boundary Type = OUTLET
Location = F2648.2646
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Mass Flow Rate = 0.63 [kg s^-1]
Mass Flow Rate Area = As Specified
Option = Mass Flow Rate
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID DEFINITION: Fluid 1
Material = Water
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = SST
END
TURBULENT WALL FUNCTIONS:
Option = Automatic
END
END
END
DOMAIN: DUCTS
Domain Type = Fluid
Location = B188,B189,B26,B27
BOUNDARY: DUCTS Default
Location = \
F21.188,F22.27,F23.189,F24.26,F254.188,F255.188,F256.188,F258.188,F25\
9.189,F260.189,F261.189,F263.189,F271.189,F272.189,F273.189,F274.189,\
F275.189,F276.189,F277.189,F278.189,F279.188,F280.188,F281.188,F282.1\
88,F2828.26,F2829.26,F283.188,F2832.27,F2833.27,F2836.188,F2837.188,F\
284.188,F2840.189,F2841.189,F285.188,F286.188,F287.26,F288.26,F289.26\
,F290.26,F291.26,F292.26,F293.26,F294.26,F295.27,F296.27,F297.27,F298\
.27,F299.27,F300.27,F301.27,F302.27,F303.27,F304.27,F306.27,F307.27,F\
310.26,F311.26,F312.26,F314.26
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: Interface Ducts RotatingCoolingDX Xdir Side 1
Location = \
F2657.26,F2658.189,F2659.27,F2660.188,F2666.188,F2667.27,F2668.189,F2\
669.26
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface Ducts RotatingCoolingDX Zdir Side 1
Location = F2662.26,F2663.189,F2664.27,F2665.188
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: EULERIAN
Domain Type = Fluid
Location = B2640
BOUNDARY: EULERIAN Default
Location = F2641.2640
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: INLET
Boundary Type = INLET
Location = F2642.2640
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Total Pressure
Relative Pressure = 185 [kPa]
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY: Interface Eulerian Intake Side 1
Location = F2759.2640
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: INTAKE
Domain Type = Fluid
Location = B67
BOUNDARY: INTAKE Default
Location = F2868.67,F436.67
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: Interface Eulerian Intake Side 2
Location = F2759.67
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface Intake IntakeMaze Side 1
Location = F2875.67
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: INTAKE MAZE
Domain Type = Fluid
Location = B2761
BOUNDARY: INTAKE MAZE Default
Location = \
F427.2761,F428.2761,F429.2761,F430.2761,F431.2761,F432.2761,F433.2761\
,F434.2761,F899.2761,F904.2761,F906.2761,F907.2761,F909.2761,F910.276\
1,F911.2761,F912.2761,F913.2761
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: Interface Intake IntakeMaze Side 2
Location = F2875.2761
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface IntakeMaze RotatingImpeller Side 1
Location = F211.2761,F2874.2761
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: ROTATING BOLT
Domain Type = Fluid
Location = B2687
BOUNDARY: Interface RotatingBolt RotatingImpeller Side 1
Location = F2699.2687,F2700.2687,F2701.2687,F2702.2687
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingBolt RotatingShaft Side 1
Location = F2672.2687
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING BOLT Default
Frame Type = Rotating
Location = \
F1096.2687,F1097.2687,F236.2687,F237.2687,F238.2687,F239.2687,F2670.2\
687,F2675.2687,F2703.2687,F872.2687,F873.2687,F888.2687,F915.2687,F93\
8.2687,F939.2687,F940.2687
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Alternate Rotation Model = true
Angular Velocity = -1256.64 [radian s^-1]
Option = Rotating
AXIS DEFINITION:
Option = Coordinate Axis
Rotation Axis = Coord 0.3
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: ROTATING COOLING CENTER
Domain Type = Fluid
Location = B2762
BOUNDARY: Interface RotatingCoolingCENTER RotatingCoolingDX Side 1
Location = F2778.2762
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingCoolingSX RotatingCoolingCENTER Side 2
Location = F2804.2762
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING COOLING CENTER Default
Location = F2781.2762
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: StaticWalls CoolingCENTER
Location = F2779.2762
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Rotating
AXIS DEFINITION:
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: ROTATING COOLING DX
Domain Type = Fluid
Location = B2787
BOUNDARY: Interface Ducts RotatingCoolingDX Xdir Side 2
Location = \
F2657.2787,F2658.2787,F2659.2787,F2660.2787,F2666.2787,F2667.2787,F26\
68.2787,F2669.2787
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface Ducts RotatingCoolingDX Zdir Side 2
Location = F2662.2787,F2663.2787,F2664.2787,F2665.2787
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingCoolingCENTER RotatingCoolingDX Side 2
Location = F2778.2787
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingCoolingDX RotatingShaft Side 1
Location = F2688.2787
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING COOLING DX Default
Location = \
F10.2787,F1000.2787,F1001.2787,F1002.2787,F1003.2787,F1004.2787,F1005\
.2787,F1006.2787,F1007.2787,F1008.2787,F1009.2787,F1010.2787,F1011.27\
87,F1012.2787,F1013.2787,F1014.2787,F1015.2787,F1016.2787,F1017.2787,\
F1018.2787,F1019.2787,F1020.2787,F1021.2787,F1022.2787,F1023.2787,F10\
24.2787,F1025.2787,F1026.2787,F1027.2787,F1028.2787,F1029.2787,F1030.\
2787,F1031.2787,F1032.2787,F1033.2787,F1034.2787,F1035.2787,F1036.278\
7,F1037.2787,F1038.2787,F1039.2787,F1040.2787,F1041.2787,F1042.2787,F\
1043.2787,F1044.2787,F1045.2787,F1046.2787,F1047.2787,F1048.2787,F104\
9.2787,F1050.2787,F1051.2787,F1052.2787,F1053.2787,F1054.2787,F1055.2\
787,F1056.2787,F1057.2787,F1058.2787,F1059.2787,F1060.2787,F1061.2787\
,F1062.2787,F1063.2787,F1064.2787,F1065.2787,F1066.2787,F1067.2787,F1\
068.2787,F1069.2787,F1070.2787,F1071.2787,F1072.2787,F1073.2787,F1074\
.2787,F1075.2787,F1076.2787,F1077.2787,F1078.2787,F1079.2787,F1080.27\
87,F1081.2787,F1082.2787,F1083.2787,F1084.2787,F1085.2787,F1086.2787,\
F1087.2787,F1088.2787,F1089.2787,F1090.2787,F11.2787,F1111.2787,F1112\
.2787,F1113.2787,F1114.2787,F1115.2787,F1116.2787,F1117.2787,F2713.27\
87,F2782.2787,F32.2787,F36.2787,F37.2787,F38.2787,F39.2787,F4.2787,F4\
0.2787,F41.2787,F42.2787,F43.2787,F44.2787,F45.2787,F46.2787,F47.2787\
,F48.2787,F49.2787,F5.2787,F50.2787,F6.2787,F7.2787,F8.2787,F867.2787\
,F868.2787,F869.2787,F9.2787,F918.2787,F929.2787,F930.2787,F931.2787,\
F932.2787,F933.2787,F934.2787,F935.2787,F936.2787,F941.2787,F942.2787\
,F943.2787,F944.2787,F948.2787,F951.2787,F952.2787,F953.2787,F954.278\
7,F955.2787,F956.2787,F957.2787,F958.2787,F959.2787,F960.2787,F961.27\
87,F962.2787,F974.2787,F975.2787,F976.2787,F977.2787,F978.2787,F979.2\
787,F980.2787,F981.2787,F982.2787,F983.2787,F984.2787,F985.2787,F986.\
2787,F987.2787,F988.2787,F989.2787,F990.2787,F991.2787,F992.2787,F993\
.2787,F994.2787,F995.2787,F996.2787,F997.2787,F998.2787,F999.2787
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: StaticWalls CoolingDX
Location = \
F1841.2787,F1842.2787,F185.2787,F204.2787,F243.2787,F245.2787,F264.27\
87,F266.2787,F265.2787,F267.2787,F268.2787,F2689.2787,F269.2787,F270.\
2787,F308.2787,F309.2787,F315.2787,F320.2787,F321.2787,F322.2787,F323\
.2787,F324.2787,F33.2787,F2780.2787,F35.2787
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Rotating
AXIS DEFINITION:
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: ROTATING COOLING SX
Domain Type = Fluid
Location = B2698
BOUNDARY: Interface RotatingCoolingSX RotatingCoolingCENTER Side 1
Location = F2804.2698
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingSpillage RotatingCoolingSX Side 2
Location = F2671.2698
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface SpillageDX RotatingCoolingSX Side 2
Location = F207.2698
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING COOLING SX Default
Location = \
F1100.2698,F1101.2698,F1102.2698,F1103.2698,F1104.2698,F1105.2698,F11\
06.2698,F1107.2698,F1108.2698,F1109.2698,F2674.2698,F2806.2698,F31.26\
98,F916.2698,F919.2698,F920.2698,F921.2698,F922.2698,F923.2698,F924.2\
698,F925.2698,F926.2698,F927.2698,F928.2698,F946.2698
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: StaticWalls CoolingSX
Location = F1856.2698,F2712.2698,F2805.2698
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Rotating
AXIS DEFINITION:
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: ROTATING IMPELLER
Domain Type = Fluid
Location = B2686
BOUNDARY: Interface IntakeMaze RotatingImpeller Side 2
Location = F211.2686,F2874.2686
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingBolt RotatingImpeller Side 2
Location = F2699.2686,F2700.2686,F2701.2686,F2702.2686
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingImpeller RotatingSpillage Side 1
Location = F2710.2686
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingImpeller Volute Side 1
Location = F2727.2686
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING IMPELLER Default
Location = \
F100.2686,F101.2686,F102.2686,F103.2686,F104.2686,F105.2686,F106.2686\
,F107.2686,F1091.2686,F1092.2686,F1093.2686,F1094.2686,F1095.2686,F10\
99.2686,F69.2686,F77.2686,F78.2686,F79.2686,F80.2686,F81.2686,F82.268\
6,F83.2686,F84.2686,F85.2686,F86.2686,F87.2686,F875.2686,F876.2686,F8\
77.2686,F878.2686,F879.2686,F88.2686,F880.2686,F881.2686,F882.2686,F8\
83.2686,F884.2686,F885.2686,F887.2686,F89.2686,F891.2686,F892.2686,F8\
93.2686,F894.2686,F895.2686,F896.2686,F897.2686,F898.2686,F90.2686,F9\
1.2686,F92.2686,F93.2686,F94.2686,F95.2686,F96.2686,F97.2686,F98.2686\
,F99.2686
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: StaticWalls IMPELLER
Location = \
F1869.2686,F420.2686,F421.2686,F422.2686,F423.2686,F424.2686,F425.268\
6,F426.2686,F70.2686,F900.2686,F901.2686,F902.2686,F903.2686,F905.268\
6,F908.2686,F1860.2686,F1867.2686,F1868.2686,F193.2686,F209.2686,F210\
.2686,F2683.2686
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Rotating
AXIS DEFINITION:
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: ROTATING SHAFT
Domain Type = Fluid
Location = B2681
BOUNDARY: Interface RotatingBolt RotatingShaft Side 2
Location = F2672.2681
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingCoolingDX RotatingShaft Side 2
Location = F2688.2681
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING SHAFT Default
Location = \
F2676.2681,F937.2681,F963.2681,F964.2681,F965.2681,F966.2681,F967.268\
1,F968.2681,F969.2681,F970.2681,F971.2681,F972.2681,F973.2681
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Rotating
AXIS DEFINITION:
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: ROTATING SPILLAGE
Domain Type = Fluid
Location = B2680
BOUNDARY: Interface RotatingImpeller RotatingSpillage Side 2
Location = F2710.2680
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingSpillage RotatingCoolingSX Side 1
Location = F2671.2680
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingSpillage SpillageSX Side 1
Location = F2722.2680,F2723.2680,F2724.2680,F2725.2680,F2726.2680
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface SpillageCENTER RotatingSpillage Side 2
Location = F1847.2680
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING SPILLAGE Default
Location = \
F235.2680,F2673.2680,F2709.2680,F73.2680,F74.2680,F75.2680,F76.2680,F\
870.2680,F871.2680,F890.2680,F914.2680,F917.2680,F949.2680,F950.2680
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: StaticWalls Spillage
Location = \
F1848.2680,F241.2680,F2682.2680,F331.2680,F332.2680,F333.2680,F334.26\
80,F335.2680,F336.2680,F337.2680,F338.2680,F339.2680,F340.2680,F341.2\
680,F342.2680,F362.2680,F395.2680,F396.2680,F397.2680,F398.2680,F399.\
2680,F400.2680,F72.2680,F201.2680
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Rotating
AXIS DEFINITION:
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: SPILLAGE CENTER
Domain Type = Fluid
Location = B2862
BOUNDARY: Interface SpillageCENTER RotatingSpillage Side 1
Location = F1847.2862
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface SpillageCENTER SpillageDX Side 1
Location = F2788.2862
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface SpillageCENTER SpillageSX Side 1
Location = F2764.2862
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface SpillageVolute SpillageCENTER Side 2
Location = F2763.2862
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: SPILLAGE CENTER Default
Location = \
F2768.2862,F2770.2862,F2790.2862,F2793.2862,F2864.2862,F326.2862,F343\
.2862,F347.2862,F349.2862,F350.2862,F351.2862,F71.2862
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: SPILLAGE DX
Domain Type = Fluid
Location = B2802
BOUNDARY: Interface SpillageCENTER SpillageDX Side 2
Location = F2788.2802
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface SpillageDX RotatingCoolingSX Side 1
Location = F207.2802
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: SPILLAGE DX Default
Location = \
F1855.2802,F2791.2802,F2792.2802,F328.2802,F329.2802,F330.2802
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: SPILLAGE SX
Domain Type = Fluid
Location = B30
BOUNDARY: Interface RotatingSpillage SpillageSX Side 2
Location = F2722.30,F2723.30,F2724.30,F2725.30,F2726.30
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface SpillageCENTER SpillageSX Side 2
Location = F2764.30
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: SPILLAGE SX Default
Location = \
F246.30,F247.30,F248.30,F249.30,F250.30,F251.30,F252.30,F253.30,F2769\
.30,F344.30,F352.30,F353.30,F354.30,F355.30,F356.30,F357.30,F358.30,F\
359.30,F360.30,F361.30,F363.30,F364.30,F365.30,F366.30,F367.30,F368.3\
0,F369.30,F370.30,F371.30,F372.30,F373.30,F374.30,F375.30,F376.30,F37\
7.30,F378.30,F379.30,F380.30,F381.30,F382.30,F383.30,F384.30,F385.30,\
F386.30,F387.30,F388.30,F389.30,F390.30,F391.30,F392.30,F393.30,F394.\
30
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: SPILLAGE VOLUTE
Domain Type = Fluid
Location = B2775
BOUNDARY: Interface SpillageVolute SpillageCENTER Side 1
Location = F2763.2775
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface Volute SpillageVolute Side 2
Location = F2811.2775
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: SPILLAGE VOLUTE Default
Location = F2767.2775
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN: VOLUTE
Domain Type = Fluid
Location = B1834
BOUNDARY: Interface Convergent Volute Side 2
Location = F1861.1834
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface RotatingImpeller Volute Side 2
Location = F2727.1834
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: Interface Volute SpillageVolute Side 1
Location = F2811.1834
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: VOLUTE Default
Location = \
F1853.1834,F1862.1834,F1863.1834,F1864.1834,F1865.1834,F1866.1834,F40\
1.1834,F402.1834,F403.1834,F404.1834,F405.1834,F406.1834,F407.1834,F4\
08.1834,F409.1834,F410.1834,F411.1834,F412.1834,F413.1834,F414.1834,F\
415.1834,F416.1834,F417.1834,F418.1834,F419.1834
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
Material = Water
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
Option = None
END
Option = None
END
TURBULENCE MODEL:
Option = SST
END
Option = Automatic
END
END
END
DOMAIN INTERFACE: Interface Convergent Volute
Boundary List1 = Interface Convergent Volute Side 1
Boundary List2 = Interface Convergent Volute Side 2
Interface Type = Fluid Fluid
INTERFACE MODELS:
Option = General Connection
FRAME CHANGE:
Option = Frozen Rotor
END
MASS AND MOMENTUM:
MOMENTUM INTERFACE MODEL:
Option = None
END
END
PITCH CHANGE:
Option = None
AXIS DEFINITION:
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface Ducts RotatingCoolingDX Xdir
Boundary List1 = Interface Ducts RotatingCoolingDX Xdir Side 1
Boundary List2 = Interface Ducts RotatingCoolingDX Xdir Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface Ducts RotatingCoolingDX Zdir
Boundary List1 = Interface Ducts RotatingCoolingDX Zdir Side 1
Boundary List2 = Interface Ducts RotatingCoolingDX Zdir Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface Eulerian Intake
Boundary List1 = Interface Eulerian Intake Side 1
Boundary List2 = Interface Eulerian Intake Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = None
AXIS DEFINITION:
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface Intake IntakeMaze
Boundary List1 = Interface Intake IntakeMaze Side 1
Boundary List2 = Interface Intake IntakeMaze Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = None
AXIS DEFINITION:
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface IntakeMaze RotatingImpeller
Boundary List1 = Interface IntakeMaze RotatingImpeller Side 1
Boundary List2 = Interface IntakeMaze RotatingImpeller Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingBolt RotatingImpeller
Boundary List1 = Interface RotatingBolt RotatingImpeller Side 1
Boundary List2 = Interface RotatingBolt RotatingImpeller Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingBolt RotatingShaft
Boundary List1 = Interface RotatingBolt RotatingShaft Side 1
Boundary List2 = Interface RotatingBolt RotatingShaft Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingCoolingCENTER RotatingCoolingDX
Boundary List1 = Interface RotatingCoolingCENTER RotatingCoolingDX Side 1
Boundary List2 = Interface RotatingCoolingCENTER RotatingCoolingDX Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingCoolingDX RotatingShaft
Boundary List1 = Interface RotatingCoolingDX RotatingShaft Side 1
Boundary List2 = Interface RotatingCoolingDX RotatingShaft Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = None
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingCoolingSX RotatingCoolingCENTER
Boundary List1 = Interface RotatingCoolingSX RotatingCoolingCENTER Side 1
Boundary List2 = Interface RotatingCoolingSX RotatingCoolingCENTER Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingImpeller RotatingSpillage
Boundary List1 = Interface RotatingImpeller RotatingSpillage Side 1
Boundary List2 = Interface RotatingImpeller RotatingSpillage Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingImpeller Volute
Boundary List1 = Interface RotatingImpeller Volute Side 1
Boundary List2 = Interface RotatingImpeller Volute Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingSpillage RotatingCoolingSX
Boundary List1 = Interface RotatingSpillage RotatingCoolingSX Side 1
Boundary List2 = Interface RotatingSpillage RotatingCoolingSX Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface RotatingSpillage SpillageSX
Boundary List1 = Interface RotatingSpillage SpillageSX Side 1
Boundary List2 = Interface RotatingSpillage SpillageSX Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface SpillageCENTER RotatingSpillage
Boundary List1 = Interface SpillageCENTER RotatingSpillage Side 1
Boundary List2 = Interface SpillageCENTER RotatingSpillage Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface SpillageCENTER SpillageDX
Boundary List1 = Interface SpillageCENTER SpillageDX Side 1
Boundary List2 = Interface SpillageCENTER SpillageDX Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = None
AXIS DEFINITION:
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface SpillageCENTER SpillageSX
Boundary List1 = Interface SpillageCENTER SpillageSX Side 1
Boundary List2 = Interface SpillageCENTER SpillageSX Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = None
AXIS DEFINITION:
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface SpillageDX RotatingCoolingSX
Boundary List1 = Interface SpillageDX RotatingCoolingSX Side 1
Boundary List2 = Interface SpillageDX RotatingCoolingSX Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = Automatic
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface SpillageVolute SpillageCENTER
Boundary List1 = Interface SpillageVolute SpillageCENTER Side 1
Boundary List2 = Interface SpillageVolute SpillageCENTER Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = None
AXIS DEFINITION:
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: Interface Volute SpillageVolute
Boundary List1 = Interface Volute SpillageVolute Side 1
Boundary List2 = Interface Volute SpillageVolute Side 2
INTERFACE MODELS:
FRAME CHANGE:
END
MASS AND MOMENTUM:
Option = None
END
END
PITCH CHANGE:
Option = None
AXIS DEFINITION:
END
END
END
MESH CONNECTION:
Option = GGI
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
Turbulence Numerics = First Order
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 500
Minimum Number of Iterations = 1
Timescale Control = Auto Timescale
Timescale Factor = 10
END
CONVERGENCE CRITERIA:
Residual Target = 1e-3
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = Yes
END
INTERRUPT CONTROL:
Option = Any Interrupt
CONVERGENCE CONDITIONS:
Option = Default Conditions
END
END
END
END
COMMAND FILE:
Version = 21.1
Results Version = 21.1
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = Yes
Large Problem = No
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: -------
Host Architecture String = winnt-amd64
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Automatic
MEMORY CONTROL:
END
PARTITION SMOOTHING:
Maximum Partition Smoothing Sweeps = 100
Option = Smooth
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
Partition Weight Factors = 0.25000, 0.25000, 0.25000, 0.25000
END
END
RUN DEFINITION:
Run Mode = Full
Solver Input File = CFX.def
Solver Results File = \
C:/Users/-------/dp0_CFX_35\
_Solution_35/CFX_003.res
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 4
Start Method = Intel MPI Local Parallel
Parallel Host List = ------*4
END
END
END
END
| Partitioning |
| ANSYS(R) CFX(R) Partitioner |
| 2021 R1 |
| Build 21.1 2020-11-09T17:12:37.550718 |
| Mon Nov 9 19:04:23 GMTST 2020 |
| Executable Attributes |
| double-64bit-int32-archfort-optimised-std-lcomp |
| (C) 1996-2021 ANSYS, Inc. |
| All rights reserved. Unauthorized use, distribution or duplication |
| is prohibited. This product is subject to U.S. laws governing |
| export and re-export. For full Legal Notice, see documentation. |
| Job Information at Start of Run |
Run mode: partitioning run
Host computer: ---- (PID:------)
Job started: Tue Feb 8 10:08:49 2022
| License Information |
