Thandiwe Radebe
  1. The external thermal conditions are not set in this current model. Reason being i would like to compare the annulus surface temperature with the experimental results.
  2. I used standard initialization with the temperature of all the domains set to 288K.
  3. I am monitoring the Static Temperature and the Liquid fraction, to ensure that the water is frozen, and to view which areas freeze quicker.
