May 23, 2023 at 5:23 pm
In stand-alone the .res file was imported in the solution block correctly. I.e. I could see the results in the CFX-Post.
When triyng to run the .res file again, I obtain the error code object of the thread. Doesn't change with number of partitions or serial calculations.
This is my original Workbench - Block AK is the where the .res solved correclty came from.
This is the brand new project where I re-create the original one:
