While there is no hard limit on the size of the domain, certain factors can affect the accuracy and stability of your simulations. Verify that the fluid properties used in your simulations are appropriate for the small-scale domain. If necessary, consider adjusting the properties, such as viscosity, density, or thermal conductivity, to match the actual conditions.
