May 24, 2023 at 9:35 am
Hello Chandra,
thanks for fast and helpfull answer.
Due to you, the issue with the coordinate data disappeared
I’m struggling a little bit to visualise the time dependant data.
prvar lists the temperature vs. time and plvar displays the time vs. temp in a graph, but where can I see the graph and how is it possible to save the prescribed time vs temperature data in a txt file
nodeid=27844
/post26
nsol,2,node,nodeid,temp !Specifies nodal data to be stored from the results file
prvar,2 !Lists variables vs. time (or frequency).
plvar,2 !Displays up to ten variables in the form of a graph.
Do I miss something?
With best regards
John M.
