In order to modify the material color, you can duplicate the material but with a different name. Then you can assign different material to different geometry, even though actually the materials have the same refractive index. It is the material name that has a color and only the newly added material can be modified.
You can click "Copy" to duplicate the material. Before duplicating, make sure the material fitting is proper.
