May 25, 2023 at 12:43 am
Yes
- The surface is exposed to atmospheric air
- I am using a time step of 1
- the solution did converge when i used the Laminar model, however with the k-e model it does not
I have noted that the default value for the latent heat of water in Ansys is 2 263 073 J/kg. Well the known value for water's latent heat is 333 000 J/kg. Is this correct?
I have exhausted all my options. ( I am starting to think that there is a problem with Ansys's back-end coding causing the model's instability)
I would advise other students learning to model solidification and melting to follow this video ANSYS Fluent Tutorial: Analysis of Melting and Solidification of Phase Change Material (PCM).
however, the creators use a steady state, which is not applicable to my model.
