May 25, 2023 at 9:59 am
Hello Eugenio,
To do this you will need to run AqwaReader as a post-solve command - there are detailed instructions included in the AqwaReader Manual, as well as a Python script that you can get started with. You should be able to access the manual from within the Aqwa Workbench editor:
- click the Help menu on the top toolbar
- click to open any of the Aqwa Manuals in the list
- once the Ansys help website opens, click 'Aqwa 2023 R1' in the top left corner of the page to see the full list of Aqwa documentation
- select 'AqwaReader Manual'.
I would suggest reading through the whole AqwaReader manual as there is important information in each section (it's not very long). I hope this helps.
Mike
