I tried with a simple pipe flow, still got the same error.
This run of the CFX GEOMETRY LICENSING PATCH 2021 R1 SP3 Solver started
at 12:00:23 on 25 May 2023 by user Stefano.CHIETI on ----------
(intel_xeon64.sse2_winnt) using the command:
"C:\Program Files\ANSYS Inc\v211\CFX\bin\perllib\cfx5solve.pl" -batch
-ccl runInput.ccl -fullname "CFD 2022_003"
Point Releases and Patches installed:
ANSYS, Inc. Products 2021 R1
SpaceClaim 2021 R1
Autodyn 2021 R1
CFD-Post only 2021 R1
CFX (includes CFD-Post) 2021 R1
FENSAP-ICE 2021 R1
Fluent (includes CFD-Post) 2021 R1
Forte (includes EnSight) 2021 R1
Polyflow (includes CFD-Post) 2021 R1
TurboGrid 2021 R1
Aqwa 2021 R1
Customization Files for User Programmable Features 2021 R1
Mechanical Products 2021 R1
Icepak (includes CFD-Post) 2021 R1
Remote Solve Manager Standalone Services 2021 R1
Viewer 2021 R1
ACIS Geometry Interface 2021 R1
AutoCAD Geometry Interface 2021 R1
Catia, Version 4 Geometry Interface 2021 R1
Catia, Version 5 Geometry Interface 2021 R1
Catia, Version 6 Geometry Interface 2021 R1
Creo Elements/Direct Modeling Geometry Interface 2021 R1
Creo Parametric Geometry Interface 2021 R1
Inventor Geometry Interface 2021 R1
JTOpen Geometry Interface 2021 R1
NX Geometry Interface 2021 R1
Parasolid Geometry Interface 2021 R1
Solid Edge Geometry Interface 2021 R1
SOLIDWORKS Geometry Interface 2021 R1
ANSYS, Inc. License Manager 2021 R1
Discovery 2021 R1.6
Geometry Licensing Patch 2021 R1 SP3
Setting up CFX Solver run ...
| CFX Command Language for Run |
LIBRARY:
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Option = Pure Substance
Thermodynamic State = Liquid
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Reference Temperature = 25 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
ABSORPTION COEFFICIENT:
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
THERMAL EXPANSIVITY:
Option = Value
Thermal Expansivity = 2.57E-04 [K^-1]
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: Default Domain
Coord Frame = Coord 0
Domain Type = Fluid
Location = B32
BOUNDARY: inlet
Boundary Type = INLET
Location = F197.32
BOUNDARY CONDITIONS:
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Normal Speed = 0.005 [m s^-1]
Option = Normal Speed
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY: outlet
Boundary Type = OUTLET
Location = F34.32
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Pressure Profile Blend = 0.05
Relative Pressure = 0 [Pa]
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
BOUNDARY: wall
Boundary Type = WALL
Location = F33.32
MASS AND MOMENTUM:
Option = No Slip Wall
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID DEFINITION: Fluid 1
Material = Water
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Fluid Temperature = 25 [C]
Option = Isothermal
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
Turbulence Numerics = First Order
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 100
Minimum Number of Iterations = 1
Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END
INTERRUPT CONTROL:
Option = Any Interrupt
CONVERGENCE CONDITIONS:
Option = Default Conditions
END
END
END
END
COMMAND FILE:
Version = 21.1
Results Version = 21.1
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = No
Large Problem = No
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: ---------
Host Architecture String = winnt-amd64
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Automatic
MEMORY CONTROL:
END
PARTITION SMOOTHING:
Maximum Partition Smoothing Sweeps = 100
Option = Smooth
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Run Mode = Full
Solver Input File = CFD 2022.def
Solver Results File = \
C:/Users/Stefano.CHIETI/Desktop/----------/-CFD_pending/dp0_CFX_Solution/CFD 2022_003.res
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END
END
END
| Solver |
| ANSYS(R) CFX(R) Solver |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| For CFX runs launched from Workbench, the final locations of |
| directories and files generated may differ from those shown. |
This run of the ANSYS CFX Solver has finished.
