Hello Chandra,
thank you for the helpfull answer.
When I apply the mentioned lines to my code:
nodeid=27844
/post26
nsol,2,node,nodeid,temp !Specifies nodal data to be stored from the results file
prvar,2 !Lists variables vs. time (or frequency).
plvar,2 !Displays up to ten variables in the form of a graph.
/out,d:\mypvar.dat
prvar,2
/out
/show,png
plvar,2
/show,close
this is the outcome in the solve.out file:
***** TIME-HISTORY POSTPROCESSOR (POST26) *****
ALL POST26 SPECIFICATIONS ARE RESET TO INITIAL DEFAULTS
*** WARNING *** CP = 418.125 TIME= 13:48:41
The data in field 3 is invalid. The NSOL command is ignored.
No data points are saved during this storage step.
/OUTPUT FILE= d:\mypvar.dat
/SHOW SWITCH PLOTS TO PNG - RASTER MODE.
Set Encoding of XML File to:ISO-8859-1
Set Output of XML File to:
PARM, , , , , , , , , , , ,
DATABASE WRITTEN ON FILE parm.xml
***** ROUTINE COMPLETED ***** CP = 419.062
PRINTOUT RESUMED BY /GOP
*GET _WALLDONE FROM ACTI ITEM=TIME WALL VALUE= 13.8116667
PARAMETER _PREPTIME = 1.000000000
PARAMETER _SOLVTIME = 150.0000000
PARAMETER _POSTTIME = 4.000000000
PARAMETER _TOTALTIM = 155.0000000
*GET _DLBRATIO FROM ACTI ITEM=SOLU DLBR VALUE= 0.00000000
*GET _COMBTIME FROM ACTI ITEM=SOLU COMB VALUE= 0.00000000
*GET _SSMODE FROM ACTI ITEM=SOLU SSMM VALUE= 2.00000000
*GET _NDOFS FROM ACTI ITEM=SOLU NDOF VALUE= 122196.000
--- Total number of nodes = 283054
--- Total number of elements = 84182
--- Element load balance ratio = 0
--- Time to combine distributed files = 0
--- Sparse memory mode = 2
--- Number of DOF = 122196
EXIT ANSYS WITHOUT SAVING DATABASE
NUMBER OF WARNING MESSAGES ENCOUNTERED= 30
NUMBER OF ERROR MESSAGES ENCOUNTERED= 0
Obviously, the nodal data isn't stored at all.
With best regards
John M.
