Hello Jackie,
On the client machine, with LS-RUN, you can go to the License menu and set the following:
- Click on the License menu in LS-RUN.
- Set the license type to LSTC_LM or Network (if you are using the standalone version).
- Set the Server hostname to the hostname or IP address of the license server.
- Make sure the Set Env. check box is checked. This will set the environment variables automatically.
Let me know how it goes.
Reno.
