Right click on the Connections folder and Insert a Fixed Joint. Select the flat face of the solid cylinder as the Reference side of the joint and select the vertex of the beam element that is touching that face as the Mobile side of the joint. The joint will allow the face and vertex to be connected in a way that transmits shear forces and bending moments from the solid to the beam.
