May 26, 2023 at 6:07 am
Hi Peter,
thanks for your answer. When I select the end vertex of the beam, Body is set to multiple and the joint does not get a green check (selecting the vertex on the other end does work). I assume that is due to the shared topography? Should I disable it? That leaves me a bit confused since in this demo, topography sharing seems to work without extra steps: https://www.ansys.com/de-de/resource-center/video/beam-and-shell-modeling-with-ansys-mechanical
