HAOYU LIU
My structure is a diameter of 15 um,thickness 2 um cylinder. What does the cureved objects below the ideal surface means? Also, should I enable the "split plc edges" ? For the gloabl setting, should I use smaller one ? My structure can't be simplified into 2D
