Guilin Sun
If you give a screenshot of the device I may suggest a solution. Basically if the cured surface of a cylinder is on a flat surface ideally, it may need very small mesh to resolve the tangent region. you can move down the clyinder a little to make them tough-deep instead of geometrical contact as a line.
