Essence
Ok, I understood. For that, you can split the edge into boundary layer edge and other in without segmented ratio. The length at which the edge can be split can be chosen by you. Either manually (arbitrarily) select the portion on edge which will split it. Or create the point at the location where you want to split.
This way, you can independently assign the divisions and Mesh laws to the two separate edges.
