Did you create an orthotropic material for the honeycomb core?  Do the Global coordinates align with the relevant axes in the othrotropic material definition?  This discussion has an example of an orthotropic material model for a honeycomb core.
You can adjust the shear modulus value to match the experimental data.  What do you have for experimental data?  How did you measure the stiffness of your Ansys model?
