May 30, 2023 at 7:44 am
Hello Taylor, thanks for the detailed answer.
Perhaps I should focus on this question:
When reading data from a monitor. with "specified position" set as interpolation.
How does the montitor decide what is the specified position? x min and x max I understand. but how does it choose the resolution? I believe through something that reads the mesh positions... this is the source of the problem. If I could get the monitor to read exatcly where I want, this can be solved without forcing it to read only at the mesh position. (which will also open a path for me to change the topology resoltuion to be different from the mesh resolution, a feature currently missing)
