That's for you to decide. If the solution has stopped changing, then it's not unreasonable to assume you've got an equilibrium condition. Whether that holds indefinitely is for you to check. Most/all engineering is based on an assumption somewhere: the reason we spend so long at Uni is to help us determine which assumption we can use, and whether it's valid for whatever we're doing.
