May 30, 2023 at 4:53 pm
Hi
Total Pressure inlet, environmental pressure hot end and cold end. I let the software calculate the hot end and cold end temperatures.
input: total pressure: 600kpa
Out put both hot and cold ends: 100kpa
for the total pressure 600kpa, -10C cold end and 87C hot end
I read many papers but I am not sure if I applied physics properly. there are two problems: 1. I can not obtain the temperature mentioned above 2. I can not see reverse flow from hot end towards cold end too.
