May 31, 2023 at 11:26 am
If the part you wish to analyze does not come into direct contact with the particles, you can follow these steps:
- In Ansys Motion, designate the part you want to analyze as a flexible body and mesh it.
- Generate the Functional Mock-up Unit (FMU). Note that there might be some warnings regarding limited support for flexible bodies.
- Import the FMU into Rocky. Once imported, the flexible body will not be visible in the simulation.
- Run the simulation in Rocky, keeping in mind that it will take significantly more time to complete.
- Launch Ansys Motion Postprocessing and open the DFR file located inside the Rocky project folder
