May 31, 2023 at 1:48 pm
Hello mjmiddle,
The edge is created using the pull tool with the copy edge option, then the goal is to project that edge on the inside surface of the nozzle.
Dividing the external surface using a plane seems to work fine i manage to create the inside edge successfully, but i m wondering if there is a better way to achieve this without having to divide the surface using a plane.
Thank you very much for your help.
