Federico Alzamora Previtali
A) What are you plotting here? Are you sure you have the same scales for both plots?
B) In general yes, low eddy viscosity means lower number of eddies, which results in low dissipation since there is less turbulence and mixing occuring, which in turn means less energy to dissipate (vice versa for high eddy viscosity).
