June 1, 2023 at 7:57 pm
Both models are based on a strain energy density function. NeoHookean is the simplest (mathematically) of all the hyperelastic options, but it also is limited to relatively small strain (<30%) and typically only curve fits well for mildly nonlinear stress strain curves without inflection points.
I would refer you to Section 4.6 of the MAPDL Material Reference Guide available online for a more rigorous explanation of all the hyperelasticity material options.
If NeoHooekan result passes all your validation requirements, then you should be fine to use it.
