Concerning the question about getting the maximum value, if I understand correctly, the problem is that everytime you go through the loop, you overwrite my_energy. I would simply use an additional storage variable like max_my_energy and initialise it to 0 before the loop begins, then in every step you should simply compare my_energy with the maximum until there, and if higher, substitute it.
*IF,my_energy,GT,max_my_energy,THEN
max_my_energy=my_energy
*ENDIF
